pieklo
Posts: 2 Joined: Fri Dec 23, 2016 8:57 pm
Post
by pieklo » Fri Dec 23, 2016 9:38 pm
Hi
I have problem when I try load any cloud then CC was crashes. I have very old laptop with core2duo t8300 4gb ram and chipset gm965 (integred graphic card gma x3100), and i think that is a problem. Is there any way to make the program work?
thanks
Posts: 8180 Joined: Wed Oct 13, 2010 7:34 am
Post
by daniel » Sat Dec 24, 2016 7:02 pm
You can try to disable all fancy options in the 'Display options' dialog (load clouds on GPU for faster display, color scale shader, etc.).
But the issue is probably related to the old graphic card (can you at least update the driver?).
pieklo
Post
by pieklo » Wed Dec 28, 2016 8:23 pm
Ok I click off GPU acceleration in display options and works fine. Thanks :)
