HPC format and coordinate grid
deepminder
Post by deepminder »
Hello Daniel!
I have faced few problems and I wanted to ask you if there is possibility to solve it in CloudCompare:
1) Opening Hexagon Point Cloud. Hexagon companies has started to use it in their software and it would be great if CloudCompare can also open it.
2) Is it possible to add grid with coordinates on the background when rendering to image? The idea is to get a raster with some information about it's position.
Thanks in advance!
Re: HPC format and coordinate grid
1) Is this format open? Or is there a SDK to read it? I couldn't find any information about it.
2) Nope, it's in the TODO list though. Meanwhile you could relatively easily create a set of polylines to do the trick with a 'poly' file: write the two vertices of each segment on two consecutive lines, and then add a blank line to separate each segment.
X0 Y0 Z0
X1 Y1 Z1
X2 Y2 Z2
X3 Y3 Z3
