Command line C2M distance
williamP
Post by williamP »
I want to batch the command line Cloud-to-Mesh distance.
I wrote this script :
cd "C:\Program Files\CloudCompare"
CloudCompare.exe -O C:\Users\Desktop\def_01_03.pts -O C:\Users\Desktop\NullScan_TIN.obj -C_EXPORT_FMT ASC -EXT TXT -C2M_DIST
The problem is that CC displays an error message : "Only one point cloud available. Be sure to open or generate a second one before performing C2C distance."
So I don't understand why it speaks about C2C distance while I ask C2M distance...
Thanks you for your answer !
Re: Command line C2M distance
Hum, that's bad indeed ;) It's probably a bug...
What version are you using?
williamP
Post by williamP »
I use the version 2.9
Ok I updated the 2.9.beta version, this should be fixed now.
Thanks for the feedback!
williamP
Post by williamP »
Your update works perfectly !
Thanks you :)
