Vertex coordinates
ilovecoffee1125
Vertex coordinates
Post by ilovecoffee1125 »
I am trying to upload some ATLS scans and the first line that appears is highlighted in pink and has strange symbols for column attributes. If I click "apply" an error message occurs reading, "at lease 2 vertex coordinates must be defined." About a week ago, these images were uploading well. Any ideas to why this is occurring? The scans will not appear.
Thank you.
Re: Vertex coordinates
Can you send me such a file? (or at least the first 20 lines for instance)
There has been an update recently to allow loading files with text labels in some columns. Even though I don't see why it would prevent you from loading your file, it must be linked to this...
And meanwhile, you should be able to 'skip' the first lines, or change the 'separator' to load your file, aren't you?
