Export Dip direction - Dip angle from planes
Re: Export Dip direction - Dip angle from planes
Not to my knowledge. The RansacSD plugin code may have changed since this post was written indeed...
WargodHernandez
Post by WargodHernandez »
Ransac will find the planes, CC can then do a bulk export like usual
I ran Ransac on a cloud I had got 176 planes returned, I selected the folder that Ransac creates with the result and used (Tools->Batch Export->Export Plane Info)
Here is the first two lines in the export csv
Name;Width;Height;Cx;Cy;Cz;Nx;Ny;Nz;Dip;Dip dir;
Dip: 000 deg. - Dip direction: 086 deg.;142.058;202.617;-18.1547;168.354;253.823;-0.00497566;-0.000287712;-0.999988;0.285305;86.6906;
I'm not sure off hand but I think you can do this in command line as well.
