Page 2 of 2
Re: points cloud to DXF
Posted: Sat Mar 23, 2019 9:21 am
Actually the cloud is saved in a DXF file in 3D. If you only see it from the top, does it mean that the software you use to load it is only 2D?
Anyway, a trick might be to rotate the cloud in CC before saving it (use the 'Edit > Apply Transformation' tool).
And for the colors, nope, DXF does not handle per-point colors.
Posted: Sun Mar 24, 2019 5:40 pm
by daniel cave
Thank you,
yes, this has worked out. Well, the idea is to transform a smart phone scan into a "traditional" 2d cave plan. At the moment I try to find out if the real point cloud as dxf is more handy or a picture (with colour information) that is scaled afterwards as a sketch in the background of the plan drawing program.
Posted: Thu Mar 26, 2020 4:09 pm
by Florian
You mentioned 3 years ago that one should be careful with exporting too many points to DXF.
Do you have an idea about the maximum amount of points to be exported, or how to alter the maximum amount? Cloudcompare seems to crash everytime when I try to export ±260.000 points.
Thanks in advance!
Posted: Fri Mar 27, 2020 1:16 pm
We use a 3rd party library to export/create DXF files.
I haven't looked at the internals of the library but there might be some limit? (even though 260 000 seems weird for a 'programmation' limit).
I'll try to check on my side.
Posted: Mon May 09, 2022 8:53 am
by pcampana_01
daniel wrote: Fri Apr 21, 2017 4:24 pm Well, I've added the possibility to save clouds as DXF files (each point is saved an Autocad 'Point' entity).
However don't try to save too many of them as the file will probably grow very fast! And I haven't been able to test the result, I'll let you do it. You can downloaded the latest 2.9 beta version.
thank you so much for the support,
i've some problems to export point clouds to dxf.
i'm working on CC2.12.1 Stereo Version, but i can't find export to dxf command.
Can you help me?
Paolo
Posted: Tue May 10, 2022 6:09 pm
Are you selecting the point cloud entity itself, and not the group that contains it?
