Automating common workflows?
Laserbrain
Re: Automating common workflows?
Post by Laserbrain »
I figured the 'density' option would output the scalar field.
"Enabling this flag tells the reconstructor to output the estimated depth values of the iso-surface vertices."
Then the density is used by
SurfaceTrimmer.exe "Trims off parts of a triangle mesh with a per-vertex signal whose value falls below a threshold (used for removing parts of a reconstructed surface that are generated in low-sampling-density regions)"
Dunno.
Maybe a clever autohotkey script could run the poisson meshing in CC.
jedfrechette
Post by jedfrechette »
The name of the vertex attribute added by the --density flag is 'value'.
Jed
Laserbrain
Oh!
Thanks, Jed!
That works.
