Page 2 of 2
Re: Error in Apply Transformation
Posted: Wed Sep 21, 2022 11:42 am
by dcobra
WargodHernandez wrote: Mon Feb 01, 2021 7:16 pm @daniel
Maybe it would be useful to add a check function for orthogonality, and a orgonalize function to our matrix class?
I will be using the inverse transformation function and am wondering if this was implemented in a new release? If not, is it correct to use the Wolfram Alpha code on the 3 rows/columns of the transformation matrix and then add the 4th column/row back in after orthogonalizing?
Posted: Thu Sep 22, 2022 5:43 pm
No, this was not implemented in the end.
But yes you are correct about the way to use the Wolfram Alpha code!
Posted: Fri Sep 23, 2022 7:35 pm
by dcobra
Great, thank you!
