Page 2 of 2
Re: Cloud Point showing up as a straight line
Posted: Thu May 09, 2024 3:50 pm
by LiDoom
daniel wrote: Wed May 01, 2024 3:50 pm And what the bounding-box looks like once you've loaded the cloud?
There's good chances that Quick Terrain Modeler does manage properly geographic coordinate systems...
Looks like this.
Posted: Sat May 11, 2024 8:18 am
The bounding-box (and more generally the entity properties) doesn't appear in this capture...
Posted: Sun May 12, 2024 7:01 pm
by LiDoom
daniel wrote: Sat May 11, 2024 8:18 am The bounding-box (and more generally the entity properties) doesn't appear in this capture...
Oops sorry, here you are. Thanks.
Posted: Sun May 19, 2024 12:12 am
by LiDoom
bump
Posted: Mon May 20, 2024 11:26 am
Yes, so you can see that the bounding box along X and Y is super small (<0.02) and super large along Z (> 420).
This is once again typical from a geographical coordinate system. You can try to rescale X and Y with the 'Edit > Multiply / scale' tool (by using a factor of 100 for instance for X and Y only). This should help you see how the cloud looks like.
But I think you should better convert the coordinates to a Cartesian coordinate system prior to importing it in CC.
Posted: Thu May 23, 2024 12:54 am
by LiDoom
daniel wrote: Mon May 20, 2024 11:26 am Yes, so you can see that the bounding box along X and Y is super small (<0.02) and super large along Z (> 420).
Thank you!!! I think changing the coordinates did the trick.
