Page 2 of 2
Re: unit of measure (density;gradient)
Posted: Mon Jun 30, 2014 3:27 pm
by Luca1988SCENE
hi daniel, honestly i didn't understand so much your speech, when you say "or more generally that its values can't change faster than the distance between points" what are you going to explain ? i have a cloud wich is derived from a registration from 4 clouds picked up by laserscanning. i have about 5 milion points in few m^2....have i to click yes or now when CC ask me if the scalar field is composed by euclidian dist ?
Posted: Mon Jun 30, 2014 3:47 pm
The most important part was "rarely in practice!": always click "no" by default...
Posted: Thu Jul 24, 2014 2:58 pm
by Luca1988SCENE
Hi Daniel, i 'm writing my thesis but i still have few questions for you ;)...
- which unit of measure has the gradient ( degrees?)?
- why the "gauss: mean" value is equal to 0.0000? when CC compute the distance between a fit plane and its cloud returns me a Gauss distribution but it don't specify me the mean Gauss value
Thanks a lot
Posted: Thu Jul 24, 2014 4:08 pm
by Luca1988SCENE
here one photo for Gauss: mean value
Posted: Thu Jul 24, 2014 4:13 pm
- the gradient is expressed in 'units of the scalar field' / 'units of distance' (because we compute something equivalent to a difference of scalar values divided by a distance between points)
- when we fit a plane on a point cloud we compute the "mean squares" solution. This solution is such that the mean distance of the points to this plane is 0 by definition.
- you can ask for the Gaussian distribution of a scalar field any time by selecting the cloud that hosts the scalar field and then calling the "Edit > Scalar fields > Compute stat. params" method (then simply select the "Gauss" distribution). The scalar field must be the active/visible one.
You should also display the Console (F8). Interesting information is displayed in it from time to time (such as the distribution parameters, etc.).
