Height Ramp
Posted: Wed Jan 07, 2015 5:18 pm
by jeniasingh
How can I generate A height Ramp in cloud compare?
Re: Height Ramp
Posted: Wed Jan 07, 2015 5:42 pm
Could you be more precise please?
Re: Height Ramp
Posted: Mon Feb 09, 2015 11:36 am
by jeniasingh
I have a point cloud of trees within a square plot of 20m* 20m. I want to show the height of each tree in a colored tabulated format.
is it possible?
Re: Height Ramp
Posted: Mon Feb 09, 2015 12:22 pm
Yes:
Re: Height Ramp
Posted: Thu Apr 16, 2015 2:53 am
by twalkemeyer
Is there a way to colour a point cloud similar to using the height ramp but for the intensity values, or any scalar field?
Re: Height Ramp
Posted: Thu Apr 16, 2015 7:20 am
Well, you can indeed use the Color Scale Manager (http://www.cloudcompare.org/doc/wiki/in ... es_Manager) so as to get a similar rendering for any scalar field (and with any values - you may have to use an 'absolute' color scale to achieve this).
Re: Height Ramp
Posted: Thu Apr 16, 2015 7:41 am
by twalkemeyer
daniel wrote:Well, you can indeed use the Color Scale Manager (http://www.cloudcompare.org/doc/wiki/in ... es_Manager) so as to get a similar rendering for any scalar field (and with any values - you may have to use an 'absolute' color scale to achieve this).
I'd tried that but it didn't change the display.
I found the Color Scale -> Current option near the bottom of the preferences window where it's necessary to select which scale to use for the point cloud soon after posting. The manager is just the database of available options.
Re: Height Ramp
Posted: Thu Apr 16, 2015 8:31 am
Well, you can also create new color scales with the Manager. And once you create them, they are automatically set as 'current'...
