CC crashes every time I use N+C
Sascher
Post by Sascher »
Hi all,
everytime I use the N+C app CC crashes without any message. I think the problem is related to the curvature because it also crashes when I try to generate the curvature "manually". Any ideas?
Cheers!
Sascha
Re: CC crashes every time I use N+C
I guess you are speaking about the qPCL Normal computation method? And when you say "computing the curvature manually you are referring to "Tools > Other > Curvature"?
If yes then it's weird because both methods have nothing in common!
What is your OS? And what version of CC are you using?
Sascher
Post by Sascher »
Thanks for reply!
excactly. I'm on Win7 (64bit) using CC v2.6.0.
I tried to reinstall both CC and the PCL files, but the problem still exists.
Thanks!
Okay, I finally found the bug. It should be fixed with the latest beta release (I've just updated it online: http://www.cloudcompare.org/).
Thanks for the feedback!
Sascher
Post by Sascher »
Thank you, Daniel! I'll give it a try later on.
Also, my obeisance to you and CC. It's fantastic to work with
Sascher
Post by Sascher »
finally I had time to process my data once more - it works! Thank you
