Create a mask
Posted: Mon Jan 26, 2015 9:29 am
by Pilaf
I was wondering if it is possibile to use a portion of a cloud as a mask to "cut" other clouds in the same shape of the mask, without using segmentation tool of course.
I tried to compute the intersection using the Mesh Boolean Operation tool but I obtained this message:
Exception caught: ENSURE FAILED
Computation failed!
Thank you very much :)
Re: Create a mask
Posted: Mon Jan 26, 2015 9:58 am
The qCork plugin behaves sometimes strangely (you have to retry multiple times until it accept to compute the boolean operation!).
Otherwise, depending on how your 'mask' cloud looks like, you can compute the distances to the cloud and then filter out the farthest points?
Re: Create a mask
Posted: Mon Jan 26, 2015 10:12 am
by Pilaf
Thank you Daniel for your super fast answer and for your suggestion: I'll try it!
What I want to obtain is the same extraction of multiple clouds starting from a given cloud; in my case, I want to extract the "roof" of a cave from many models created using different parameter's setting and then compare the extractions (the "roofs").
So maybe the easiest way to do that is to segment all the clouds in the same time and then do the comparisons.
Re: Create a mask
Posted: Mon Jan 26, 2015 10:27 am
Indeed.
Or if your extraction area is a box, you can use the command line (with the CROP option).
Re: Create a mask
Posted: Tue Jul 21, 2015 3:03 pm
by franezd
HI Daniel,
I also get the same error as Pilaf when trying to perform a boolean operation between two meshes:
Computation failed!
Your help is appreciated
Franz
Re: Create a mask
Posted: Tue Jul 21, 2015 4:16 pm
There's a bug in the Cork library that makes this happen from time to time. Generally you just have to restart the process and it works... generally ;).
Do you confirm?
