Opening *.dp (Dot Product) file.
Alma Rahat
Post by Alma Rahat »
Dear all,
I have been trying to open a *.dp file with Cloud Compare. However, in every occasion it comes up with the following error.
[Load] Can't guess file format: unhandled file extension 'dp'
Is it a bug? Or am I doing something wrong here?
I would really appreciate your help. Thanks very much.
Best,
Alma
Re: Opening *.dp (Dot Product) file.
What version are you using?
livinjd
Post by livinjd »
I am having the same problem
And on what OS? With which version? ;)
Here is a suggestion (assuming you are using Windows): try to install the "Visual C++ Redistributable Packages for Visual Studio 2013"
http://www.microsoft.com/en-US/download ... x?id=40784
Can you give me some feedback afterwards?
protoblade
Post by protoblade »
I have the same issue with version 2.13.2 (currently latest) for mac
I don't think the DP format is supported on macOS.
protoblade
do you know if its windows only or linux is capable of operating it ?
I believe it's a Windows-only plugin.
