Page 1 of 2
Point cloud info in command line
Posted: Wed Apr 01, 2015 12:28 pm
by Seb_B
Is it possible to get general info of the point cloud loaded in command line? Eg: number of points, min X, max X, min Y, max Y, ...?
Il might help to use the -CROP command after.
Thanks,
Re: Point cloud info in command line
Posted: Wed Apr 01, 2015 12:55 pm
Nope. Can you develop on this maybe? What are you willing to do exactly?
Posted: Wed Apr 01, 2015 2:01 pm
by Seb_B
If I know the minimum and maximum in z, I would like to do "slices" of a thichness of 0.5 m (with the -crop command) each 1 meter along the z axis of my point cloud.
For my loop, I need to know the minimum and maximum in z.
Posted: Wed Apr 01, 2015 2:35 pm
by Seb_B
Ok, not 0.5m of thichness each 1 m! This was not a good example! But somthing like thichness of 0.2 m each 1 meter.
Posted: Wed Apr 01, 2015 2:55 pm
Ok. The current version (2.6.2.beta - 'CleanMeshCutter' branch) has a new command line option that allows to apply the 'Crop' algorithm in this way (with automatic repetition, etc.). It can even start from relative coordinates (i.e. 'min' or 'max' bounding-box coordinates). The command name will be 'CROSS_SECTION' (it relies on a XML file for the parameters as it requires too much parameters/options).
So if you are able to compile this version on your side, you can take a look at the code in 'ccCommandLineParser::commandCrossSection' to figure out how it works. Otherwise you'll have to wait for the next version (with an updated documentation ;).
Posted: Tue Apr 28, 2015 2:07 pm
by jason3d
Are there any prebuilt downloads for the 2.6.2 beta?
Posted: Tue Apr 28, 2015 8:20 pm
I've just uploaded a fresh version here:
http://www.cloudcompare.org/release/Clo ... in_x64.zip (EDIT: updated with the latest beta version on the 5/18).
Posted: Wed Apr 29, 2015 5:16 pm
by jason3d
About the new beta version 2.6.2
Posted: Thu Jul 23, 2015 10:58 am
by Rahul
What are the new features you have added.
Sir you did a great job the cc software is excellent because of this software I am able to do my m.tech desertation work on Lidar.thank you ..
Posted: Thu Jul 23, 2015 1:39 pm
For proper 'release notes' you'll have to wait for the official release.
But meanwhile you can look at the 'history.txt' file next to the executable.
