merge mesh with jpg texture
kelly1151
Post by kelly1151 »
I would like to merge some obj mesh with jpg texture.
This is a 3D model composed of four parts. Each part has obj, jpg, and mtl.
I could merge four mesh perfectly in CloudCompare.
However, when I open the merged mesh, the texture does not show well.
Could you please check a sample data which can be downloaded from here?
http://firestorage.com/download/4a87064 ... ff3019935b
file name: sample.zip (about 10MB)
download password :sample
Many thanks,
Kelly
Re: merge mesh with jpg texture
Interesting. There mus be a bug in the way texture coordinates are merged.
I'll look at this asap.
Okay I've fixed the bug. You can test the latest beta version:
http://www.cloudcompare.org/release/Clo ... in_x64.zip
kelly1151
Post by kelly1151 »
That’s perfect!! THANK YOU!!I love you!!
You're welcome ;).
I've just updated the beta version to make this merge method more robust (see this post: viewtopic.php?t=1267).
kelly1151
Post by kelly1151 »
Thank you daniel! I downloaded the version and the merge worked fine.
