Export z-change values
flavia.sistilli
Post by flavia.sistilli »
Hi Daniel and Dimitri,
I'm here again to ask your help!
I don't know if you remember my work on small areas of embryo coastal dunes…
I have finished the field work and also to compare the clouds with M3C2 plugin.
Now, I should quantify the z-change for each area and for each period.
It would be possible to export the histogram of the difference’s cloud ?
I would obtain the number of point for each scale value and thus the percentages values.
I hope I have explained well my issues.
Flavia
flavia.sistilli
Re: Export z-change values
I forgot ...
I have already tried to export .asc file of clouds but they are too big for Excel computations…
it would take an “ informations” already compressed, such as a histogram or I don’t know…
thanks
Does the histogram computed by CC suits you? ('Edit > Scalar fields > Show histogram'- you can change the number of bins with the mouse wheel by the way).
If yes, then with the latest beta version, you can export the histogram to a CSV file (see the small icon in the top-right corner).
Here is a link to the beta version:
http://www.cloudcompare.org/release/Clo ... in_x64.zip
flavia.sistilli
Thanks Daniel,
This is exactly what I need!
Just a question, Is there a way to set custom bin range?
I saw that now they are automatic.
have a good day
Flavia
Indeed the bins are always regularly spread over the [min distance ; max distance] range.
You can of course reduce this range by segmenting the cloud (with 'Edit > Scalar fields > Filter by value') and then compute the histogram on the resulting cloud (with the right range).
