Various little bugs in the latest version
Dimitri
Post by Dimitri »
on the 13/12 version :
. When a cloud with a scalar is segmented, the scalar is not properly transferred to the new cloud (a unique number is applied to all points in the new segmented cloud).
. The same if you filter the cloud according to its scalar values. All scalars formely attached to the cloud loose their value in the segmented cloud.
Cheers
Re: Various little bugs in the latest version
Ah, sorry for the inconvenience (it is a typical "over-bug": when correcting the first one, I created a new one!).
The online version has been updated (same filename, as I'm a bit lazy).
Dimitri
Post by Dimitri »
HI Daniel,
thanks. Allez, un p'tit pour la route :
. The "precision" box for the scale does not appear anymore (only square size and font size).
. Any chance you could remove the limit on the max color sat value so that it can be set to any value ?
. And the little bug when only 4-5 color ramp interval are chosen and the scalars are negative and positive : some intervals have the same color (nothing urgent).
Note : i'll be on holiday from next tuesday and then back to France, so I won't bother you until next year ! By the way, joyeuses fêtes à tout le monde !
Dimitri
