Build error - MS Visual Studio Express 11 2012 x64, QT5
PetkoSmetko
Post by PetkoSmetko »
Hi
I am trying to build CC only.
When I run 'ALL_BUILD' then I have got this error:
Error	1	error : process for C:/Users/admin/Documents/GitHub/CC/trunk/build/libs/qCC_db/moc_ccClipBox.cpp failed:	C:\Users\admin\Documents\GitHub\CC\trunk\build\libs\qCC_db\AUTOGEN	QCC_DB_LIB
Error	2	error : process for C:/Users/admin/Documents/GitHub/CC/trunk/build/libs/qCC_db/moc_ccOctree.cpp failed:	C:\Users\admin\Documents\GitHub\CC\trunk\build\libs\qCC_db\AUTOGEN	QCC_DB_LIB
Error	3	error : process for C:/Users/admin/Documents/GitHub/CC/trunk/build/libs/qCC_db/moc_ccProgressDialog.cpp failed:	C:\Users\admin\Documents\GitHub\CC\trunk\build\libs\qCC_db\AUTOGEN	QCC_DB_LIB
Error	4	error MSB3073: The command "setlocal
cd C:\Users\admin\Documents\GitHub\CC\trunk\build\libs\qCC_db
if %errorlevel% neq 0 goto :cmEnd
C:
"C:\Program Files (x86)\CMake\bin\cmake.exe" -E cmake_autogen C:/Users/admin/Documents/GitHub/CC/trunk/build/libs/qCC_db/CMakeFiles/QCC_DB_LIB_automoc.dir/ Debug
:cmEnd
endlocal & call :cmErrorLevel %errorlevel% & goto :cmDone
:cmErrorLevel
exit /b %1
:cmDone
if %errorlevel% neq 0 goto :VCEnd
:VCEnd" exited with code 1.	C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppCommon.targets	124	5	QCC_DB_LIB
and so one.
I could see that this files are missing on my HDD.
Here is my CMake configuration:
I am trying to build only basic CC without any unnecessary features.
  • Software configuration:
  • Windows 7 x64 - in Virtualbox
  • CMake v3.3.2
  • QT 5.5.1
  • MS Visual Studio Express 11 2012 x64
  • CC source code -clone from github -depth=1
Thank you
Peter
Re: Build error - MS Visual Studio Express 11 2012 x64, QT5
Well, the moc files should be dynamically generated. And this is apparently failing on your side.
Can you try to create the Visual project in a folder 'outside' of the 'trunk' (i.e. don't use '/trunk/build' as build directory)?
I believe there's a warning about this in the documentation. However I'm not sure this is the reason of the problem here ;)
PetkoSmetko
Hi Daniel
Thank you for your response.
I found out when I run cmake.exe -E cmake_autogen from command line that I am missing MSVCP120.dll.
I downloaded and installed Visual C++ Redistributable Packages for Visual Studio 2013
Peter
PetkoSmetko
Advice: download Visual Studio and Qt which are compatible (I downloaded Qt for Visual Studio 13 and Visual Studio 2012 - and I was surprise that it doesn’t want to link project together).
