installing plugins
Posted: Tue Nov 10, 2015 10:39 pm
by montarob
Please I would like to install the plugin qAnimation in my CloudCompare 2.6.0, what procedure should I follow?
(use linux - Ubuntu 04.14)
Thank you
Re: installing plugins
Posted: Wed Nov 11, 2015 6:47 am
You can't. You need the 2.6.2 (or newer) version. This means you have to compile it yourself or wait for Romain to pavkage a new version - but the 4.14 version may be too old already !).
Or you can use Windows in a kind of virtual box?
Posted: Wed Nov 11, 2015 9:14 am
by montarob
Thank you for your answer Daniel.
I could work in windows. In this case, how should I do?
Posted: Wed Nov 11, 2015 10:42 am
On Windows, simply download and install the 2.6.2 version (or the 2.6.3.beta version). The plugins are already integrated.
Posted: Wed Nov 11, 2015 1:53 pm
by montarob
Thank you!
Posted: Thu Dec 03, 2015 4:53 pm
by Bruce Jamieson
I would like to load the qANIMATION plugin. Running CC 2.6.2 on Windows 8.1. qANIMATION is grayed in the Plugin menu. The dll exists in in the CloudCompare/plugins folder.
Posted: Fri Dec 04, 2015 7:33 am
If the plugin's icon stays grayed out, it means you haven't selected the viewport objects that will be used for generating the animation. See the documentation of the plugin or the tutorial video.
