Normals batch
BernieF
Normals batch
Post by BernieF »
Hi all,
I have a set of about 1200 point clouds (.asc) without normals. I understand that I can compute the normals with the batch function, but can I also run the re-orientation as batch? Are there any limits about the number of point clouds?
Thanks a lot,
best,
Bernie
Re: Normals batch
In fact with the command line mode normals can only be computed for structured files (i.e. PTX and DP files).
You can't compute or orient normals with the command line on unstructured cloud yet (there's no technical limitation but the time / motivation to do it ;).
And if it was possible, there would be no limitation to the number of clouds.
