Crash on Display>Render to File
Posted: Mon Feb 08, 2016 11:13 am
by Steve L~
I get a crash each time I select Display>Render to File but only when the Console is NOT displayed.
Re: Crash on Display>Render to File
Posted: Tue Feb 09, 2016 7:45 pm
I can't reproduce the issue on my side.
What version are you using? (I'm using 2.6.3.beta). And what are the rendering parameters?
Posted: Wed Apr 13, 2016 9:31 am
by Steve L~
Daniel,
A bit more on this as I've managed to re-produce it.
Im using v 2.6.3
Turning the console OFF and then rendering to file, the console re-appears with the message that the render has completed. That's OK
With EDL enabled and the console ON, the console re-appears with the message that the render has completed. That's OK
With EDL enabled and the console OFF, the console partially re-appears - half is 'under' the Properties pane) then it crashes.
Posted: Sat Apr 16, 2016 9:25 am
Thanks for the feedback.
I still can't reproduce this issue on my side (even with your accurate directions), but:
- we have changed a lot of things in the 2.7 version (new version of Qt, etc.)
- the Console doesn't pop-up anymore when rendering the screen ;)
I'll let you test the new version (as soon as it's out) and confirm if it's better or not.
Posted: Fri May 13, 2016 2:50 pm
by Steve L~
Yup, Fixed in 2.7.0 !
