Error opening bin files in 2.6.2
Posted: Fri Feb 26, 2016 8:59 pm
by aknight0
I have several very large bin files (> 5GB) that I've been working with in CC. I recently updated to 2.6.2, and found that I could no longer open my files. Either cloud compare would crash, or it would return an error saying that the file may be corrupted. I downgraded to 2.6.1, and the files open just fine. Any ideas why this would happen?
Re: Error opening bin files in 2.6.2
Posted: Fri Feb 26, 2016 9:50 pm
Indeed it was a bug with Qt if I recall properly. This has been fixed in the 2.6.3 beta version. Can you try it?
Posted: Fri Feb 26, 2016 10:44 pm
by aknight0
That fixed it. Thanks for the quick reply!
Posted: Fri May 06, 2016 12:21 pm
by adririquelme
Dear all,
Since last update to 2.7.0 I am getting errors when opening large .bin files (close to 10GB)
[14:08:17] [BIN] Version 4.3 (coords: float / scalar: float)
[14:09:28] File seems to be corrupted
[14:09:28] An error occurred while loading '2016_Villajoyosa_Analisis': see console
This was not happening in previous version.
Posted: Sun May 08, 2016 5:33 pm
Or maybe the issue is that the file format has changed and the readers are not handling the old files correctly...
What was stored in this file? Only point clouds?
Posted: Wed May 18, 2016 9:37 pm
by adririquelme
Yes, only point clouds.
When using 2.6.2 I can load the .bin, but when 2.7 I found this error
