Moving the viewport
simcovr
Moving the viewport
Post by simcovr »
Good morning,
I'm wondering if there is a way to pan the viewport while trace a polyline or a polygon selection.
The problem is that if you want to pan, you have to use your rightmouse button and this stop the polyline creation.
I tried several key combination, but without success.
It could be very usefull if you can pan the view using another key/button combination while you are creating polylines.
Thank you very much
By the way I found maybe a bug in the version 2.7: if you try to merge more polylines the software crashes.
Re: Moving the viewport
Nope you are right, there's no key binding for panning the view. We could add this to the TODO list.
simcovr
Post by simcovr »
Thank you Daniel.
I think that this feature will be very usefull also in many cases like the polygon selection tool.
Thank you for your support
