Export of estimated values of RANSAC
Posted: Thu Jun 16, 2016 8:42 am
by Marcus
I want to estimate DBH of trees from TLS forest data. I already tried the RANSAC shape detection on a small subsample (3 trees) and it worked quite well. The final application of RANSAC should be on an entire forest site with more than 30 trees. Is there a possibility to export the estimated metrics (radius and height) of all fitted cylinder to an csv or txt file wit one click?
That would be very helpful to do further statistics on that data.
I'm not sure if this question was already asked. However, I did not found any post here.
Regards,
Marcus
Re: Export of estimated values of RANSAC
Posted: Thu Jun 16, 2016 6:02 pm
Currently there's no such method.
Posted: Fri Jun 17, 2016 6:38 am
by Marcus
thanks for your reply.
Maybe you could implement such an option in the future. Might be worth.
Regards,
Marcus
