☑ Error 2 while compiling CC 2.7 on Ubuntu
All about Linux portage
swiss_knight
Post by swiss_knight »
after a bunch of warnings while generating the compilation files with cmake-gui 3.5.1 :
http://pastebin.com/raw/1v15FWXp
It seems to end :
Generating done
But after that, when I run make the compilation stops at around 44% :
Here are the last lines from the make command stdout :
[ 43%] Building CXX object libs/qCC_glWindow/CMakeFiles/QCC_GL_LIB.dir/ccGLUtils.cpp.o
/home/username/Downloads/CloudCompare/libs/qCC_io/ShpFilter.cpp: In member function ‘virtual CC_FILE_ERROR ShpFilter::loadFile(QString, ccHObject&, FileIOFilter::LoadParameters&)’:
/home/username/Downloads/CloudCompare/libs/qCC_io/ShpFilter.cpp:1516:17: error: ‘isnan’ was not declared in this scope
   if (isnan(zMin))
/home/username/Downloads/CloudCompare/libs/qCC_io/ShpFilter.cpp:1516:17: note: suggested alternative:
In file included from /usr/include/c++/5/random:38:0,
                 from /usr/include/c++/5/bits/stl_algo.h:66,
                 from /usr/include/c++/5/algorithm:62,
                 from /usr/include/x86_64-linux-gnu/qt5/QtCore/qglobal.h:85,
                 from /usr/include/x86_64-linux-gnu/qt5/QtCore/qchar.h:37,
                 from /usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:41,
                 from /usr/include/x86_64-linux-gnu/qt5/QtCore/QString:1,
                 from /home/username/Downloads/CloudCompare/libs/qCC_db/ccLog.h:29,
                 from /home/username/Downloads/CloudCompare/libs/qCC_db/ccSerializableObject.h:22,
                 from /home/username/Downloads/CloudCompare/libs/qCC_db/ccObject.h:22,
                 from /home/username/Downloads/CloudCompare/libs/qCC_db/ccHObject.h:22,
                 from /home/username/Downloads/CloudCompare/libs/qCC_io/FileIOFilter.h:22,
                 from /home/username/Downloads/CloudCompare/libs/qCC_io/ShpFilter.h:24,
                 from /home/username/Downloads/CloudCompare/libs/qCC_io/ShpFilter.cpp:20:
/usr/include/c++/5/cmath:641:5: note:   ‘std::isnan’
     isnan(_Tp __x)
libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/build.make:418: recipe for target 'libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/ShpFilter.cpp.o' failed
make[2]: *** [libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/ShpFilter.cpp.o] Error 1
CMakeFiles/Makefile2:467: recipe for target 'libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/all' failed
make[1]: *** [libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 43%] Building CXX object libs/qCC_glWindow/CMakeFiles/QCC_GL_LIB.dir/QCC_GL_LIB_automoc.cpp.o
[ 43%] Linking CXX static library libQCC_GL_LIB.a
[ 43%] Built target QCC_GL_LIB
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
Any help is greatly appreciated !
Thanks a lot.
I'm on Ubuntu 16.04.
Re: Error 2 while compiling CC 2.7 on Ubuntu
What compiler / version are you using?
And can you try to replace isnan by std::isnan in ShpFilter.cpp? Does it change anything?
swiss_knight
$ g++ -v
Using built-in specs.
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 5.3.1-14ubuntu2.1' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-5 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-libmpx --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-5-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-5-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 5.3.1 20160413 (Ubuntu 5.3.1-14ubuntu2.1)
Replacing "isnan" by "std::isnan" on line 1516 of the /libs/qCC_io/ShpFilter.cpp in CloudCompare directory seems to work, the make command has passed this file without errors. Thanks.
Here is the next step, in file ./libs/qCC_io/RasterGridFilter.cpp :
[ 20%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/RasterGridFilter.cpp.o
/home/username/Downloads/CloudCompare/libs/qCC_io/RasterGridFilter.cpp: In member function ‘virtual CC_FILE_ERROR RasterGridFilter::loadFile(QString, ccHObject&, FileIOFilter::LoadParameters&)’:
/home/username/Downloads/CloudCompare/libs/qCC_io/RasterGridFilter.cpp:387:44: error: ‘class QImage’ has no member named ‘pixelColor’
             QColor origColor = quadTexture.pixelColor(k, j);
/home/username/Downloads/CloudCompare/libs/qCC_io/RasterGridFilter.cpp:430:25: error: ‘class QImage’ has no member named ‘setPixelColor’
             quadTexture.setPixelColor(k, j, qRgba(C.r, C.g, C.b, C.a));
libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/build.make:730: recipe for target 'libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/RasterGridFilter.cpp.o' failed
make[2]: *** [libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/RasterGridFilter.cpp.o] Error 1
What version of Qt are you compiling with?
swiss_knight
I think it's Qt5... How could I check that ? There is nothing about Qt in the configure output of cmake-gui.
Here are the search results for "qt" in the entries on cmake-gui :
I think you need Qt 5.5 at least.
But you would have had an error otherwise. This means the setPixelColor must be in Qt 5.6 only...
Either you replace it by something else (like setPixel) or you comment it. I'll fix this on github.
swiss_knight
If this may help :
$ qmake --version
QMake version 3.0
Using Qt version 5.5.1 in /usr/lib/x86_64-linux-gnu
And this other command gives something else :
$ pkg-config --modversion QtCore
4.8.7
But :
$ pkg-config --modversion Qt5Core
5.5.1
Hope this helps...
I'll keep track of changes on github if I find how to :) I'm pretty new to this.
I updated the code myself. Hope it works now on your side.
swiss_knight
Good evening Mr. daniel,
Thanks for updating! :)
( I've got some new warnings when generating with cmake-gui : http://pastebin.com/raw/TL9H80ZS )
And the same error appears when 'make'-ing the program, here are the last lines :
[ 49%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PovFilter.cpp.o
[ 49%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/E57Filter.cpp.o
[ 49%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/ImageFileFilter.cpp.o
[ 49%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PVFilter.cpp.o
[ 50%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/DepthMapFileFilter.cpp.o
[ 50%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/RasterGridFilter.cpp.o
[ 50%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/DxfFilter.cpp.o
/home/username/Downloads/CloudCompare/trunk/libs/qCC_io/RasterGridFilter.cpp: In member function ‘virtual CC_FILE_ERROR RasterGridFilter::loadFile(QString, ccHObject&, FileIOFilter::LoadParameters&)’:
/home/username/Downloads/CloudCompare/trunk/libs/qCC_io/RasterGridFilter.cpp:387:44: error: ‘class QImage’ has no member named ‘pixelColor’
make[2]: *** Waiting for unfinished jobs....
CMakeFiles/Makefile2:411: recipe for target 'libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/all' failed
Here are the options related to 'qt' in cmake-gui :
The one in green was empty, I had to manually insert this path. I hope it's correct.
Here is what lays in there : $ tree -d /usr/lib/x86_64-linux-gnu/qt5
http://pastebin.com/raw/vb0QZuBa
I'm trying to be the most complete, let me know if you need some more informations.
Regards.
Okay, 2nd attempt (check github ;)
