☑ qCSF compile (make) error on Ubuntu 16.04
swiss_knight
Post by swiss_knight »
after a completed compilation without this plugin, I ended up with an error when trying to compile while enabling INSTALL_QCSF_PLUGIN in cmake-gui.
Here is the last lines of the 'make' process :
[ 56%] Generating qrc_qCSF.cpp
[ 56%] Generating ui_CSFDlg.h
Scanning dependencies of target QCSF_PLUGIN
[ 56%] Building CXX object plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/Cloud2CloudDist.cpp.o
In file included from /home/username/Downloads/CloudCompare/trunk/plugins/qCSF/Cloth.h:28:0,
                 from /home/username/Downloads/CloudCompare/trunk/plugins/qCSF/Cloud2CloudDist.h:4,
                 from /home/username/Downloads/CloudCompare/trunk/plugins/qCSF/Cloud2CloudDist.cpp:1:
/home/username/Downloads/CloudCompare/trunk/plugins/qCSF/Particle.h:35:2: error: ‘size_t’ does not name a type
  size_t nearestPointIndex;//��Ӧ��lidar�����ٽ��������� index  nearest lidar point
plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/build.make:75: recipe for target 'plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/Cloud2CloudDist.cpp.o' failed
make[2]: *** [plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/Cloud2CloudDist.cpp.o] Error 1
CMakeFiles/Makefile2:1542: recipe for target 'plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/all' failed
make[1]: *** [plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 56%] Building CXX object plugins/qPCL/PclIO/CMakeFiles/QPCL_IO_PLUGIN.dir/QPCL_IO_PLUGIN_automoc.cpp.o
[ 56%] Built target QPCL_PLUGIN
[ 57%] Linking CXX shared library libQPCL_IO_PLUGIN.so
[ 57%] Built target QPCL_IO_PLUGIN
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
The strange characters here come as they also are in my terminal stdout. It's not a copy/paste error or whatever.
I'm running Ubuntu 16.04, kernel : 4.4.0-28-generic, Qt 5.5.1 (and libLAS 1.8.0)
Thanks !
Regards.
ps: oops, do not hesitate to move the thread to the developer section if needed.
wpqjbzwm
Re: qCSF compile (make) error on Ubuntu 16.04
Post by wpqjbzwm »
hi, @swiss_knight.
We fixed these bugs several days ago, but it seems the modifications have not been updated to github, so we put it here temporarily, just overlap by files in the attachment.
Please download it and discuss it in http://www.danielgm.net/cc/forum/viewto ... 7031#p7031.
Thank you for feedback.
wpqjbzwm
Post by wpqjbzwm »
it seems that size_t is not found. it should be modifed to "std::size_t" .
we created a pull request on the github, but their exists some conflicts, which need to be fixed to get merged.
swiss_knight
Thank you, it seems to build correctly with your new files :
  • Cloth.h
    Particle.h
    PointCloud.h
    Rasterization.cpp
Re: ☑ qCSF compile (make) error on Ubuntu 16.04
@wpqjbzwm You'll have to fix the conflict on your branch:
https://help.github.com/articles/resolv ... mand-line/
wpqjbzwm
Post by wpqjbzwm »
we have fix the conflicts, and the updated files have been mergred into the main trunk.
