Error '[ccGLWindows: paintGL / FBO start] OpenGL error: out
gonzalotap
Post by gonzalotap »
When the message saying '[ccGLWindows: paintGL / FBO start] OpenGL error: out of memory'
What kind of memory is concerned
Re: Error '[ccGLWindows: paintGL / FBO start] OpenGL error:
The memory here is the graphic card's. FBO is a way to render the 3D scene directly into a texture, in order to refresh the 3D view quickly (very usefull when moving the window, or while manually segmenting entities - we just have to redraw the polyline over the 3D view texture, thus improving drastically the frame rate with big clouds).
I never encountered this error yet: how CloudCompare reacts after that? Did it crash?
gonzalotap
The error appears when you render to file and you increase the above 6x zoom
In this particular mode, the FBO texture size is N^2 times the screen size (for a zoom factor of N). So for high zoom values, the texture size will overflow the graphic card memory.
For instance, if your current 3D view is 1024*1024 (= 1Mb * 4 = 4Mb as we are in RGBA mode), then a factor of 6 implies a texture of size 4*6*6 = 144 Mb (and it's generally hard to find a contiguous block of this size and/or a driver that handles such big textures).
