Faro Plugin
filipecaixeta
Faro Plugin
Post by filipecaixeta »
I downloaded CloudCompare source code and compiled in windows but I realized that Faro plugin doesn't come with the source code. Where can I find it ?
Re: Faro Plugin
Indeed the FARO plugin is closed source for now. Mainly because the FARO LS sdk is not public and you need a developer license id (if you had all this I could send it to you the plugin sources I guess - I'll just need to see the signed NDA I guess). Mind that the sdk is only available on Windows (afaik).
tsyxulei
Re: Faro Plugin
Post by tsyxulei »
Hi daniel
I want to get Faro plugin source code.I have Faro LS sdk license key . Could you send me source code?
Thanks for your work
Re: Faro Plugin
Can you send me a private message to 'cloudcompare [at] danielgm.net'?
tsyxulei
Re: Faro Plugin
Post by tsyxulei »
Hi daniel
I have sended my license key to your email
