3D PHOTO MODELING
ingoplem
3D PHOTO MODELING
Post by ingoplem »
Please i would like to know if there is any procedure for developing a 3D model from photos in cloud compare.
thank you.
Re: 3D PHOTO MODELING
No you have to use external tools (e.g. Visual SFM, Autodesk 123D or Micmac are free)
ingoplem
Post by ingoplem »
Please with the external tools, can i use Agisoft Photoscan.
thank you.
Oh yes, it's a very good (commercial) tool.
All these tools will basically produce either a point cloud or a triangular mesh.
ingoplem
Post by ingoplem »
Good morning
So please does it mean that Cloud Compare cannot be used for modeling?
It depends on what you mean by 'modelling' but the answer is probably 'yes, CloudCompare is not a (mesh) modelling tool' :D
ingoplem
Post by ingoplem »
Modelling as in importing photos(images) into cloud compare and generating it into a 3D model.
daniel wrote:No you have to use external tools (e.g. Visual SFM, Autodesk 123D or Micmac are free)
ingoplem
Distance
Post by ingoplem »
please could there be the case that cloud/cloud distance
and cloud/mesh distance icons just go off ( they look unenabled in the tools)?
Augustine Tetteh Oplem
You have to select two entities so that they become enabled: 2 clouds or one cloud and one mesh, or 2 meshes but mind that in this case CloudCompare will only use the vertices of the compared mesh to compute the distances.
