select overlap area from two dataset
Posted: Fri Mar 31, 2017 5:27 pm
by geolux
I have two drones surveying and there is a part of them that is overlay.
I would erase this area and leave only the two adjacent portions
Re: select overlap area from two dataset
Posted: Fri Mar 31, 2017 7:10 pm
I guess you could compute the distance between A and B, and remove all the points that are below a given distance. And then do the same between B and A?
Posted: Sat Apr 01, 2017 3:47 pm
by geolux
Yes, but I can remove the points that are below a given distance? How I can select it
Posted: Sat Apr 01, 2017 5:46 pm
Edit > Scalar field > Filter by value
