Line Width
I/O Design
Line Width
Post by I/O Design »
I've imported a dxf with about 400 lines. I'd like to change the line width. In the line properties I can see the Line width is set to Default Width. Is there a way to change the default?
Re: Line Width
We need to add this option indeed. Hopefully soon
I/O Design
Re: Line Width
At this time, is there any way to modify the line width for multiple lines at the same time or can they only be modified individually?
Re: Line Width
The default line width can now be changed as the default point size (in the top-left corner of the 3D views, when you hover the mouse cursor there).
I've updated the latest beta version online.
