[Load] Can't guess file format: unhandled file extension 'XXX'
Posted: Mon Jun 26, 2017 1:58 pm
by PabloC
Hi.
I'm on an ArchLinux computer and I updated my distro this morning (including Qt I guess).
I'm not able to load any file in CloudCompare anymore.
Don't know if it's related but neither a brand new clone nor my development version can now load files.
PS: I'm using regular ASCII files at the moment.
Re: [Load] Can't guess file format: unhandled file extension 'XXX'
Posted: Mon Jun 26, 2017 7:54 pm
Hi Pablo,
Many problems have occurred with ArchLinux recently...
Is it happening when dropping a file on the 3D view, or even when you use the loading dialog and specify a specific file filter?
Can you maybe run CC in debug mode and trace into "FileIOFilter::LoadFromFile"?
Posted: Tue Jun 27, 2017 7:39 am
by PabloC
daniel wrote:Hi Pablo,
Same behavior for both the drag-and-drop and the QDialog window.
Thanks for the hint, I'll give a look at FileIOFilter::LoadFromFile and come back.
Posted: Wed Jun 28, 2017 12:30 pm
by PabloC
Can't find what's wrong for now.
It works fine with a fresh clone using an up-to-date KUbuntu.
EDIT : the main difference here is that there are format filters on the *buntu distros and they're not here anymore using the ArchLinux. As far as my understanding of the process goes, you rely on the file extension to select a loading algorithm. But without any enxtension hint, CC just gives up on this selection step.
Posted: Fri Jun 30, 2017 10:04 am
Interesting... The default file 'filters' are loaded at startup time (see main.cpp, line 229):
FileIOFilter::InitInternalFilters(); //load all known I/O filters (plugins will come later!)
The
InitInternalFilters method simply creates the I/O filters (ASCII, BIN, LAS, etc.) and registers them in a singleton container.
Maybe this singleton is not correctly accessed by the main application (as it's created in the QCC_IO_LIB library) but it shouldn't be an issue as the QCC_IO_LIB is statically linked...
Posted: Tue Jul 11, 2017 2:19 pm
by PabloC
All right, here is the solution I found :
cd path/to/cc
mkdir build
cd build
cmake .. -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=~/.local
make install
Here, everything works as expected.
But when in need of the Debug version :
cmake .. -DCMAKE_BUILD_TYPE=Debug
make install
And here, CC does not have the filters and does not allow me to open files.
Next :
rm -rf ~/.local/lib/everythingLinkedToCC
make install
Then, CC works as expected.
In the end it's just that the install process
does not replace the required libraries when switching the
CMAKE_BUILD_TYPE field.
So, nothing Qt related in this issue.
EDIT :
I tried to build+install in Release mode, start CC, build+install in Debug mode and start CC on a *buntu and got no issue.
So it could come from CMake on Arch or anything else in the universe.
Conclusion for Arch users : manually clear the libs while switching the
CMAKE_BUILD_TYPE solve this issue.
Posted: Tue Jul 11, 2017 7:42 pm
I don't know how it works on Linux: does the libraries have the same name in debug and release modes? Are they output in the same folder?
On Windows (with Visual Studio or code::blocks) the release and debug configurations are different, and generally the library names also. Therefore we don't have this kind of issue.
Posted: Wed Jul 12, 2017 8:00 am
by PabloC
Hi Daniel.
Debug and Release libs both go in the same directory.
The only difference is the 'd' at the end of the file name in debug mode.
As a short term solution I use this command :
[ ! -f install_manifest.txt ] || xargs rm < install_manifest.txt
It removes every previously installed files (listed in the install_manifest.txt file which is CMake generated) on my system before reinstalling the updated ones.
It's equivalent to some kind of
