I want to process a large number of files using the Noise filter and was wondering if there was a command line utility for it? Found this http://www.danielgm.net/cc/forum/viewto ... line#p4103 from two years ago which says there isn't a command line utility, but thought I'd check again since it's been a while since then.
If not, is there any way to batch process a number of files using the GUI?
Thanks!
Noise filter in command line
Re: Noise filter in command line
You know have access to the SOR filter via the command line.
See http://www.cloudcompare.org/doc/wiki/in ... _line_mode and http://www.cloudcompare.org/doc/wiki/in ... SOR_filter.
I did find the SOR filter utility, but noise filter http://www.cloudcompare.org/doc/wiki/in ... ise_filter is giving me better results, hence why I was trying to find the command line version for it.
Thanks for getting back to me!
As Angup143 above of this topic, I would like to use Noise filter in command line because I have best results with this tool (in comparison with SOR filter on walls) Does a command line exist for it ?
Thanks a lot,
Guillaume
Thanks a lot,
Guillaume
Nope, this tool has not been ported to the command line yet...
