Plugin Development - Memory Leak
Posted: Tue Oct 24, 2017 8:28 pm
Any tips or tricks to keep from acquiring memory leaks? I have recently been messing with the code to work on some perosnal plugins, however am starting to notice that I have memory leaks. If i process a cloud through my plugin, and then delete the cloud from the dbtree using the UI, I see residual memory being used in my task manager (That is more memory is being used than when cloudcompare was launched, however theres no clouds being stored - at least not to the users vision)
If you have any advice for tracing, tracking, and fixing memory leaks, it would be greatly appreciated.
