Page 1 of 2
Load a label list
Posted: Mon Oct 30, 2017 9:44 am
by westergu
Is it possible to load and visualize 3d points with labels in CC? I have a list of 3D points that all have uniqe names (control points). I would really like to visualize these points togheter with their names, like when you have a "point pick list".
In the Point picking tool you can save the picked points in the format "label name,x,y,z", but I can not find a way then how to open such kind of formats. I thought I could trick the program that my control points is a "Picked point list" with labels.
Is there a way how to do this?
Best regards,
Gustav Westerlund
Re: Load a label list
Posted: Wed Nov 01, 2017 9:35 am
We'll have to work on this, but it should be feasible.
Posted: Sun Nov 05, 2017 11:39 am
Ok, here it is: http://www.cloudcompare.org/release/Clo ... up_x64.exe
I'll let you give it a try.
Daniel
Posted: Tue Nov 07, 2017 5:44 am
by westergu
It worked perfectly! Super many thanks!
Best regards,
Gustav
Posted: Wed Feb 13, 2019 2:31 pm
by Paradizelozt
Hi, i have the exact same problem. I need to visually see labels on a set of control points, in order to perform an align point pairs operation.
It looks like you found a way to address the problem, which is great! But the link you provided no longer works. Could you please reactivate it?
Just to say a big thanks for providing such a magnificent software. I recently made a sizeable cash contribution on account of using it so much. You sir are a Saint.
Posted: Wed Feb 13, 2019 9:52 pm
The official 2.10 version is now online (no need to download the beta anymore ;)
Posted: Thu Feb 14, 2019 7:39 am
by Paradizelozt
That's great, but which tool is used to perform this function?
Posted: Thu Feb 14, 2019 7:33 pm
You actually have to load the points (with labels) as a text/ASCII file.
On each line you will have the coordinates of each point (X Y Z) as well as other fields (colors, normals, etc.) and the label. Then you can choose the corresponding column to be loaded as "labels". That's all.
Posted: Wed Feb 20, 2019 12:04 am
by Paradizelozt
Many thanks Daniel, I'll give it a try :)
Posted: Thu Oct 31, 2019 3:16 pm
by dannyht
First off, many thanks for this software! I will be sending over some data sets that my team is working with for the CC dev team to play with.
I also have points that have a unique identifier and would love to be able to have this unique identifier appear when I pick points. I have tried to load in points with labels with the method described above, but CC freezes with large point clouds (I'm importing a file with ~2mil points). I can load smaller point clouds, but it is wayyy slower than normal. Even with a beefy desktop with 32gb ram and a gtx 960 GPU.
Is there a way to assign labels but not "enable" the labels automatically? Like a toggle to show labels of selected points or individually or just have them included when you pick points to a list?
Thanks a ton!
