Global Shift/Scale
Posted: Thu Mar 15, 2018 7:06 pm
I have a question about the global shift/scale feature. I am using drone data for large point clouds (~100 acres). Is it still appropriate to use the global scale? I am looking for centimeter accuracy, not micron accuracy.
Do you always recommend shifting point clouds? I know an object a few meters wide and a large ground area are two different scenarios. In this case, how much precision is lost? Will I be able to keep cm accuracy? Again, I am not concerned about anything smaller than 0.001.
Thank you for sharing this great program with us, it's been really helpful!
