Command line - SF to RGB
vincent denis
Post by vincent denis »
Hello Daniel,
I have a quick question to you. My project is to apply SF from time LAS import (data from dynamic scanning) and export it to new LAS or E57 files.
I don't understand why i can't apply -SF_CONVERT_TO_RGB into my command line (i have always the same error message : Unknow or misplaced command)
this is my command line :
"C:\Program Files\CloudCompare\cloudcompare"  -o "01.laz" -SF_CONVERT_TO_RGB FALSE -C_EXPORT_FMT E57 -SAVE_CLOUDS
Can you help me?
Thank you
(it's not my first post on your forum, but i loose my email account >_< )
Re: Command line - SF to RGB
Which version of CC are you using?
vincent denis
2.7.0
i download the last version (2.9.1) to try
vincent denis
Same error message with 2.9.1 version ...
Ah it's only in the 2.10.alpha version :D
vincent denis
Omg it's written !!!!
It's my dumb side! I read 2.01 .....
I Will try it as soon as possible, thank you Daniel.
vincent denis
Ah indeed that work fine with 2.10 but this version don't read time value from LAZ files ....... so i'm stuck
Waiting for 2.10 beta version
Hum, well it should read time values actually...
