Page 1 of 2
Riegl rxp-files
Posted: Mon May 14, 2018 12:52 pm
by penord
Thank you for the great project. I have one question. I understood that it is possible to work with Riegl-pointclouds? However, I cannot open rxp-files with the Mac-version. What should I do?
Best wishes,
Paulina
Re: Riegl rxp-files
Posted: Tue May 15, 2018 1:09 am
Indeed, the Riegl plugin is only working on Windows...
Re: Riegl rxp-files
Posted: Tue May 15, 2018 7:16 am
by penord
Thank you for the reply. Do you know if it is possible to get the plug in to Mac? I am new relatively in the field and do not understand so much about technology. My background is in human geography.
Paulina
Re: Riegl rxp-files
Posted: Sun May 20, 2018 4:00 pm
Sadly I believe the RXP plugin can only work on Windows...
Re: Riegl rxp-files
Posted: Sun May 24, 2020 4:40 am
by Lukas_251
daniel wrote: Sun May 20, 2018 4:00 pm Sadly I believe the RXP plugin can only work on Windows...
Do I understand correctly that the Riegl plugin is only able to read Riegl files, but not to write them? Or is there away to export to rdbx again after editing a pointcloud (also to just simply convert a las file to rdbx)?
Re: Riegl rxp-files
Posted: Sun May 24, 2020 2:00 pm
I believe it is indeed read-only.
Re: Riegl rxp-files
Posted: Fri Aug 07, 2020 6:52 pm
by Jonathan B
so version 2.11 can open Riegl rdb, rsp, & rds file formats from riscan but I don't see anyway to open an rxp file straight from the scanner. Am I missing something? Is there an external plugin I have to install? I need to be able to open an rxp file. I am running windows.
Re: Riegl rxp-files
Posted: Fri Aug 07, 2020 9:12 pm
There are normally 2 Riegl plugins... I wonder if one might be missing in the v2.11 distribution?
Re: Riegl rxp-files
Posted: Sat Aug 08, 2020 12:03 am
by Jonathan B
The only plugin that is obviously Riegl oriented QRIEGL_IO_PLUGIN.dll
I have a copy of 2.10, 2.9, and 2.6 and that is the only .dll file with riegl in the name.
Re: Riegl rxp-files
Posted: Mon Aug 10, 2020 8:09 pm
Hum, maybe that's the issue then... I'll have to check that when I get back in front of my computer ;)
