deformation analysis
Kamyar
Post by Kamyar »
Hello everyone,
I'm trying to run M3C2 to calculate the deformation analysis. These perceptions are used to calculate the structural changes in the excavation wall.To do this, I've scanned at different times.
1- Can I expect the M3C2 to calculate accurately?
2- What should be the method of the project?
3- How to set the important parameters to get the best results?
4- How to document and write outputs in this way?
Thanks in advance
Kamyar Taghavi
Re: deformation analysis
Yes, M3C2 can be very accurate. But you'll definitely need to read the documentation (at least the wiki: http://www.cloudcompare.org/doc/wiki/in ... 2_(plugin), but I would strongly advise you to read the article if you want the best result). Otherwise you have the 'guess' button ;)
