Loading many bin files
Posted: Fri Aug 24, 2018 9:02 am
by jb.barreau
We have a pc with the following configuration:
-Intel Core i7 5820K 3.3GHz
-Geforce GTX 921Ti
-128Go RAM
-SSHD Seagate 2TB FireCuda Gaming SSHD
Our current need is to load dozens of bin files simultaneously, each with several tens of meshes. The goal is to display subsets of meshs regardless of their membership of this or that bin. Bin size varies from a few hundred MB to several tens of GB.
Since the recent acquisition of the previously mentioned SSD hardware, it appears that the display time is greatly improved. However, the Ram memory becomes full as soon as we load more than 128GB, without it going down once everything is loaded into cloudcompare.
Is there a way to go beyond the 128GB without buying more memory?
Thank you in advance for your help.
Re: Loading many bin files
Posted: Fri Aug 24, 2018 8:24 pm
Hum, CC is not optimized to work with meshes... It's already surprising that you manage to load such big files ;).
Maybe another user has more experience with such big meshes?
