Bulk .OBJ Export
Posted: Fri Oct 05, 2018 2:29 pm
by Steve L~
I'd very much like not to have export meshes as OBJ's one at a time. It would be great if the selection set is all meshes there was an option to export as OBJ (currently only BIN, FBX and DXF is permitted) - even if separate OBJs were created for each mesh it would save an awful lot of time.
Re: Bulk .OBJ Export
Posted: Fri Oct 05, 2018 7:54 pm
Yes, actually when you select multiple entities, CC will only let you select file formats that can save several entities in a single file (which is not the case of OBJ).
Saving one file per entity would be indeed the solution... But one has to implement it ;)
