Page 1 of 2
Opening files
Posted: Tue Feb 26, 2019 4:15 pm
by GraceP97
I recently installed cloudcompare but I can't seem to open any files including ply, obj or stl files?
Re: Opening files
Posted: Tue Feb 26, 2019 10:06 pm
Do you mean that you get error messages?
Re: Opening files
Posted: Wed Feb 27, 2019 7:50 am
by GraceP97
I don't get any message when I press 'open' none of the files are visible
Re: Opening files
Posted: Wed Feb 27, 2019 8:33 am
by GraceP97
My scans are from nextengine (scanstudio) if that helps
Re: Opening files
Posted: Wed Feb 27, 2019 11:43 am
by GraceP97
I can now open files in cloudcompare when opening directly from file explorer (still not directly from cloudcompare) but cannot open multiple files into one cloudcompare window
Re: Opening files
Posted: Fri Mar 01, 2019 10:38 pm
Weird... Which version are you using?
Re: Opening files
Posted: Fri Mar 01, 2019 11:11 pm
by Adam
Hi Grace,
I'm using the same scanner (NextEngine) and I have no issues in opening any files. I'm just curious, what are you using it on? happy with it?
Re: Opening files
Posted: Mon Jul 08, 2019 3:21 pm
by kalliopikout
I have the following problem:
I import a point cloud as .bin, then I export it as .las but when I am trying to re-import it on CC
all the scalar fields are lost except for the "intensity".
Do I do something wrong when I am exporting the file?
I also get an error while I am trying to re-import on CC, even though I am changing the filter as you have proposed in other relevant topics.
I am using version 2.9.1.
Thank you!
Re: Opening files
Posted: Mon Jul 08, 2019 6:19 pm
LAS files only support some specific scalar fields with very particular names (see the LAS specifications). So any 'unknown' scalar field will be ignored by CC.
However, with the latest versions (2.11 and maybe also 2.10) additional fields can be saved. It's the only way to squeeze non-official fields in a LAS file. And it may not be supported by all programs...
Re: Opening files
Posted: Tue Jul 09, 2019 7:41 am
by kalliopikout
daniel wrote: ↑Mon Jul 08, 2019 6:19 pm
Thanks for your fast response.
I was talking about the basic scalar fields that CC supports, like "user data, point source ID etc".
I downloaded 2.11 version and this is solved, as wells as the problem of importing .las files exported by CC.
