Ransac: Quantifying error
Pimax18
Post by Pimax18 »
I was wondering if there is a simple way to determine the error Ransac is doing when fitting planes ?
An indice for each plane generated, based on the position of the points (distances from the plane) used for example
Thank you,
Pierre
Re: Ransac: Quantifying error
The RansacSD plugin generates the subsets of points corresponding to each plane fitted, as well as the planes themselves (as 'plane' entities, below the cloud).
Just highlight the two entities (cloud and plane) and compute the distances (with the 'Cloud to Mesh distances' tool). You'll get in the console the corresponding RMS I believe (or you can fit a Normal distribution and read the standard deviation for instance).
It would be possible to automate this process relatively easily if you have some programming skills.
Pimax18
Post by Pimax18 »
This what I was looking for, thank you !
Pierre
