Planes
Posted: Fri Jun 28, 2019 1:41 pm
Primary Issues:
Is there any easy way to ensure I am tracing a polyline so that all selected points remain in the same plane?
Also, when rotating/translating meshes is there any way to line it up perfectly with the coordinate system (maybe define a normal and then use the normal to align the mesh)?
Background:
I am trying to shrink wrap a polyline at various sections along a cylinder mesh in order to sample points from the polyline to calculate the centroid. On that note, if anyone has better methods for calculating the centroid of irregularly shaped segments let me know
Secondary Issue:
On a side note when I try to trace a polyline around the cylinder I often get sections of the polyline that jump through the middle and then continue following the cylinder's surface.
Thank you!
Background:
Secondary Issue:
Thank you!
