Set Bounding Box
Posted: Thu Jul 18, 2019 2:26 pm
by Felix92
I have to pointclouds, which are already aligned. At the beginning I subset the data by Using the "Cross Section"- Function. There I can set the center and the width of each Bounding Box, which are I define as the same:
Example: Center( x: 1, y:2, z:0), Width (x:16, y:16,z:13)
But after I export or create the subset die dimensions of my bounding boxes changes to
( x: 1, y:2, z:0.182), Width (x:16, y:16,z:11.7127)
Is there a way to fix the bounding box?
Re: Set Bounding Box
Posted: Fri Jul 19, 2019 7:12 am
The bounding box fits the actual points in the cloud. This is probably why the box shrinks and its center shifts a little.
So apart from adding fake points to force the bounding box extents, there's no way to set the bounding box size.
