point selection inside a sphere at x,y,z and radius r
cuatcside
Post by cuatcside »
is it possible to select/segment out all the points within a sphere centered at x,y,z and radius r?
Thanks.
cuatcside
Re: point selectioninside a sphere at x,y,z and radius r
Post by cuatcside »
or is it possible to develop a plugin that reads a csv file with x,y,z,r values for multiple spheres and segment out the pointcloud with points inside those spheres..
Thanks.
Re: point selection inside a sphere at x,y,z and radius r
Well you can always develop a plugin.
But you can achieve that by computing the distance from the point cloud (as 'compared' entity) to another point cloud with all the spheres centers (as 'reference' entity). Then you can filter out the points that are below the distance 'r' (the radius) with 'Edit > Scalar fields > Filter by value'.
