Ransac`s Plugin
Posted: Thu Sep 06, 2012 10:40 am
by gonzalotap
Good morning, someone could give some explanation about the meaning of the parameters of the Ransac`s plugin.
Daniel, this question for you:
You can apply with this plugin make the algorithm find only some kind of primitive in particular?
Best Regards
Re: Ransac`s Plugin
Posted: Fri Sep 07, 2012 12:52 pm
for more information on the parameters, I guess you should read Schnabel's artcile (I must admit I haven't done it myself ;).
And for my part: Schnabel's code only look for planes, spheres, cones, cylinders and torus. And CloudCompare can display all of them but the latter ( torus - just because I was a bit lazy - I'll try to add the corresponding code soon).
In fact, CC only tessellates the corresponding primitives to generate standard meshes (so the missing code for torus is simply the function that generates a triangular mesh from the torus parameters). But as those meshes are generally much bigger than the actual part of the point cloud they match, those meshes are hidden by default (apart from the planes that can be easily cropped depending on the cloud subset extents).
Best
Re: Ransac`s Plugin
Posted: Mon Sep 10, 2012 2:06 pm
by jfhullo
To give a little bit more infos about this plugin, you can define (only in the code for the current version) which kind of primitives you want to find.
Il would be easier to create a GUI like checkboxes to select which type you want to reconstruct, but this is not currently the case in CC.
Regards,
JF
Re: Ransac`s Plugin
Posted: Thu Feb 28, 2013 11:14 am
It's (finally) done!
And this is a great addition to this plugin as it let you get a much cleaner result if you only search for one type of primitive. By the way I added torus and cone to the supported list (for display on CC's side).
It will appear on the next release.
Re: Ransac`s Plugin
Posted: Mon Mar 04, 2013 1:36 pm
by jfhullo
Wonderful Daniel!!! Thanks a lot.
JF
