Subsample across scans
Darius_bd
Post by Darius_bd »
Greetings!
I wonder if CC can do spatial subsample of many scans inside an E57 and taking them all as a whole when it comes to subsampling it. Like, two scans may have no more density than 0.01m but when registered together there could be many points in less than 1cm apart. Is it possible to run the subsample taking into account neighboring scans?
Thanks!!
Re: Subsample across scans
Not easily. You can merge the scans (with Edit > Merge) and keep the original scan index as a scalar field. Then use the 'Subsample' tool, and eventually separate the scan again (one by one) with 'Edit > Scalar fields > Filter by value'...
Darius_bd
Post by Darius_bd »
That's not a bad idea! And you think there's a way to make a batch separate-by-scalar-field?
Darius_bd
Post by Darius_bd »
Hi me from the past.
There's a tool nowadays that can do what you wanted. It's found in "Edit > Scalar Fields > Split cloud (integer values)" and this will unmerge / separate each scan according to its original cloud index value. Just make sure to have that SF selected on the merged cloud before running it.
It's a pretty handy command!
Yes indeed!
