Importing 3D shapefile
andre.carrilho
Post by andre.carrilho »
I have a 3D shapefile (POLYGONZ) which is not opening correctly in CloudCompare:
[SHP] Shape -640747693 has an invalid shape code (-98784248)
((Tested on 2.10.2 and 2.11 alpha ))
However, it goes all right when I export the shapefile as 2D (POLYGON).
It is strange because I used to open the same file before in CloudCompare, but I got my PC formatted recently and don't remember what version I used before.
Thank you in advance,
André
Re: Importing 3D shapefile
Can you send it to me? (admin [at] cloudcompare.org).
So the file is corrupted, just waiting to know how it was generated ;)
andre.carrilho
Hi Daniel
Thank you very much for your reply.
The file was indeed corrupted. It was created with a script written in C++. However, it had a problem as pointed out by yourself.
I was using the wrong function from Shapelib: "SHPCreateSimpleObject()" instead of "SHPCreateObject()".
I`m sorry for posting as a bug of CloudCompare.
